texas_bugeye
https://bringatrailer.com/2009/08/29/turner-1-restored-1959-950-sport/
I freind of mine just bought this little guy.
Its a neat little car shares a lot of the same parts with my bugeye. One neat feature was the white control pulls on the dash,they grab your eye after only seeing them in black before also the wheel being white is different. It sports a tube frame and a warmed over 1275. It also has some finned drum brakes all the way around not sure if they are alum.w steel inserts or are just steel.I will varify next weekend.
It being all glass and tube the bonnet is ever so fragle it locks down with 2 1/4 turn locks that require an allen wrench to open.THe really odd the is it a sports car made to run SCCA but it has suiside doors! Very straight up simple car except for the top it must have a dozen lift dot's across the wind screen you would be soaked and dry again by the time you got it all up and you inside. The wipers are really wierd they have a screw that attaches the blade frame to the arm. Thinking of changing Garys name to THE BIG SWISS after buying this one as he has to fold himself up to get inside but when your in it is pretty much a BugEye
