Lynn Kirkpatrick
I'm getting ready to start a rebuild of a stock MGB motor (#18GK-WE-H 4071). This is the one with a knock while under acceleration, with around 40,000 miles on it. I'll change all the bearings, etc., but I have a few questions.
As I'm reassembling the bearings (assuming the journals are OK, fits OK, etc) should I coat, or wet the bearing surfaces with anything like Castrol or Amsoil or STP or whatever for protection at initial startup?
If I get a cam with more lift and I have the head milled 0.060", will I need different lifters, pushrods, or rocker arms? There is some adjustment on the rockers, but is it enough?
In my Bentley book, talking about milling the head, it says "check the valves at full lift to ensure that the exhaust valves do not foul the top face of the cylinder block." It sounds like the valves won't hit the piston top, but the top edge of the cylinder. (?) How likely is this? If the cylinders are bored out 0.030" will that make a difference?
Is there any benefit of switching to a Weber carb over the twin SU's. I have tuned the SU's on my '68 without a lot of hassle. Is a Weber easier, or give more performance/economy?
And finally, how likely is it that I'll need to replace
timing chain, damper, etc?
Thanks for any advise, I'm trying to get as much as possible on hand so that I'm not stopping and starting, waiting on parts.
Thanks!
Thanks!
