What are the best points for lifting the car using a floor jack? I am wanting to go over the brakes and found that the one of the four points used for inserting the factory supplied jack is rotting out and deforms under pressure.
Does any one know if the factory jack points can be rebuilt, for a price less that of the total cost of the car?
One other thought. I had just recently received this car from my son, rebuilt the cylinder head and took it for a drive. Great, performs even better than my old MGB (which my son got - guess who got the best of that deal). But the gears grind a little when I shift, especially down. Could that be clutch hydraulics and/or adjustment? Clutch itself? gear box? Note that the idle was running a bit high - I found that the throttle return spring was quite loose.
Thatnks,
Bob
Thatnks,
Bob
