Hi all, the 79 Midget I purchased had a manifold from a 75-76 1500 engine with the EGR valve mounted down near the manifold/pipe flange. This is the only piece that was replaced by the original owner, because of a crack, which is not stock. My goal is to have all proper parts as originally installed, as the car is otherwise in excellent shape with zero rust (southern CA car).
I recently purchased the correct manifold with the EGR fitting at the top center of the manifold.
I am now removing all the smog equipment (CA smog equip)to get a bit more performance here in Denver.
I have not been successful in finding the correct bolts/plugs to plug the EGR hole at the top of the manifold and a 2nd pipe fitting about 1/2 way down the manifold. I tried measuring but I am not sure if they are standard or metric threads. The EGR fitting is a coarse thread and the other fitting is a fine thread. They are both 3/4" but I am not positive.
Has anyone removed the EGR and plugged these holes? If you can provide the bolt sizes used that would be great.
I know I can just leave the EGR valve installed and disconnect the vacuum line, but I would like to remove it (and store it) and clean up the engine compartment at the same time.
Thanks for any help.
Dave
Dave
Hi Guest!
