I have a 1970 GT6 with dual cd strombergs. I broke down the other day and wouldn't run right. I figured it was a carb issue. When I took the filter cover off the one carb was spraying gas out a hole on the right hand side at about 2 oclock. I rebuilt the carbs and found a diapham ribbed in this carb. I put them back on and the car started and ran fine for a couple of minutes and then the gas started to spray again out of the same carb. If I stick my finger over it the car still runs fine and no gas spray.
So what is it. Did I not get the float set right or what. Everything else looks ok and the only thing I can guess is that the float has something to do with this. It this a pressure release area if to much gas gets in the bowl. Help. The other carb is working great.
