G
the one i bought doesn't have instructions.
+ve to the center, right?
Yes, exactly. This is why I mentioned positive ground versus negative ground cars. On a positive ground car you have to insure that the outer is insulated from the metal chassis of the car or else you get a major short circuit. The only other way is to connect it reversed to match the car, and use a cable adapter to reverse it back for the items you plug in.martx-5 said:Wouldn't using the outside shell for earth on a positive ground car reverse the polarity of the socket?? Those sockets are usually used to power stuff that is polarity sensitive, and is looking for the center terminal to be positive.
