I've noticed that two different kinds of valve stem seals are used on 1275 heads. One is cup shaped, and the other is just an O-ring slipped over the stem. So, a couple questions:
1. Does the O-ring really do anything? Seems it might seal a bit at the point where the valve is completely open, but nothing else.
2. It seems to me that the cup shaped seal might seal too well--I mean, to the degree that ever happens in an LBC. I imagine the valve still need a bit of exposure to oil, to lubricate it in the guide. Doesn't this kind of seal prevent that?
3. The head I'm working on had the O-ring seals on all valves. The gasket kit I bought has only four cup-shaped seals, presumably for the intakes. Is there any reason to put seals on the exhaust valves?
