Rob_0_Matic
The hole at the bottom of the oil pump cavity..can I tap it and put a plug in it? I put a new pump in and it leaked out the escape passage past the bottom of the pump. What is this hole for? Why is there a hole which allows a direct passage to the atmosphere? Where the original pumps using this hole for a return into the oil pan? 1968 sprite Mark IV
