58Custom
Recently, I pulled a 1275/ribcase from a junkyard and found a new, never run clutch set in between. The flywheel had also been refaced. Problem is, the PO had either overtorqued the pressure plate bolts or used the wrong ones because the threads are stripped. Any way I can fix the threads or is it a freshly refaced doorstop?
