A few weeks ago my overdrive has started to disengage in 4th, after I have driven roughly 20 to 30 miles. What happens is typically the overdrive works fine when I start, the throttle switch and dash switch do their job, I can turn on the OD in 3rd or 4th and it will stay on until I switch it off and rev the motor up a bit. When the car has been driven 20 to 30 miles the OD in 4th will disengage, sometimes nearly immediately, sometimes after a couple of miles or more. It does not make any difference if I am accelerating or not, it just disengages, and often will come back on then disengage again. The oil level, SAE30 mineral, is OK. I have cleaned the filter under the drain plug and adjusted the solenoid lever per the factory book instructions. I have installed a new Lucas solenoid, makes no difference. This started to happen recently, with no change whatsoever to the electricals, before the OD worked well. Strangely it does it in 4th but so far not in 3rd, the OD in 3rd works as it should, though not be honest I do not use it as often in 3rd.
Here it's nearly impossible to find a mechanic who is knowledgeable about OD's so I need to get a few pointers on what is most likely to be wrong. Thanks
Patrick
Patrick
