100M Carburetor Question
d_valentino
The fuel pipe that goes from carb to carb for a 100M, is that the same pipe used on a regular 100? If so does anyone know a good source for one? Moss used to sell one for the BN1 - BN2, it was U shaped with a down tube that connected to the fuel line but they stopped selling it. AH Spares' doesn't have the down tube.
Hi, I do not have a positive answer for you . However, you might contact the following in the order presented:
British Car Specialties
Healey Surgeons
Sports $ Classics
---Keoke
Yes, the carb to carb union is the exact same pipe for the HS4 or HS6 carb setup.
The only difference is the choke cable bracket on the carbs - the mount holes will need to be filed a bit to make it fit, but otherwise everything else should be the same.
You can also get the union from either British Car Specialists (California), Bob Yule at Autofarm (Canada), or UK suppliers Cape International, or ahead4healeys.com. Maybe BCS will have an original with the down tube
Always order your parts from an Austin Healey specialist!
