RobT
As part of my winter maintenence/repair work, I measured the crank shaft end float on my TR250 for the first time today - 10 thousands of an inch, which is out of spec according to the book (.006-.008). But should I start to worry yet? Or just remeasure it in a couple of thousand miles and check again? And if I do replace the thrust washers, is there a prefered option? (I seem to remember someome doing an uprated "all brass" or "all bronze" replacement to the white metal OEM washers?)
Again, many thanks for putting up with an old fuss pot's questions,
Rob.
Rob.
