jsfbond said:and how do I test the coil to see if its working?
martx-5 said:jsfbond said:The easy way is to pull the coil wire from the distributor, grab the metal end of the wire and have someone crank the motor over. The harder you hit the opposite wall in the garage will determine how good the coil is... :laugh: <span style="font-weight: bold">Seriously, don't do that unless you like 20,000 volts coursing through your body. </span>
Good thing you put the disclaimer on there... LOL.
Better yet, disconnect one of the low tension wires during the test. Otherwise you may get a false reading if the points are closed/shorted (the ignition warning light is another path to ground).martx-5 said:The primary winding is measured between the two small posts of the coil. Do all of this <span style="font-weight: bold">without</span> the ignition on.
