What would you check? - maintenance items by date
No bathroom schedule, but 25+ years in IT does things to a person. Or maybe I was always like this. 🤷‍♂️
If 25 years did that imagine what you have coming at 40. Don't ask how I now.
Going get very expensive at the 10-year tire intervals. But the spreadsheet puts the maintenance into perspective.
I'd always rather know, then at least I can plan a little bit. Only way I'm going to keep 4 old vehicles and a motorcycle on the road without going crazy or broke or both! :crazyeyes:
Hey, everything is getting expensive, old or newer. I had a headlamp fail on my daily driver and when I went to replace the bulb found that it wasn't replaceable. Yep integrated into the assembly and could be removed, poor design decision I think. Anyway had to replace the whole front assembly on that side, cost $1400 and about $100 for labor. Couldn't find it cheaper, even the little repair shops had to get it through a dealer as it wasn't available otherwise. So all cars are getting absurd with pricing for the car and parts down the road.
Rear axle seals (making poor choices all over the brake shoes...). Every 6 months? Or whenever you fancy a quick peek.
Lube your prop annually.
I had a friend with an Aston Martin. Same story with the tail light.
Reada.ble manuals!
