Wanted Missing or discontinued parts???
Hersh
I'm missing a part for my 1953 MGTD. Is there someone there that might help me locate this part? It' s a right front axle spacer bearing. Part Number 264-090. At least that is what Moss Motors has called this? But they also have informed me that this part isn't available anymore???
How about ebay?
I guess I need the correct generator and all the parts on up to the cable housing protruding from the fire wall. Oh yea that cable housing is empty of it's contents. Also here is what I presently have concerning the generator. I surmise it's from an older triumph one that doesn't have that correct tail end attachment either?? Help?????
If you can find a family owned old parts store they can cross reference it for you. Or a machine shop can cut one to fit.
Take your bearing to parts store with real parts people , numbers on bearings can be upgraded. Machine shop will take a new bearing and cut to size of old beating.(y)
The right hand steering knuckle on this vehicle has stripped threads... Looked one E-bay but couldn't find one!! I keep asking myself what's nexf???
Take to machine shop, weld more metal and rethread!
The Right Front Steering knuckle nut on this 1953 MG TD is stripped?? Who might be able to inform me as to both: are they either ANF Threads, or Unified Threads, or BSF threads~~~and the size of the steering knuckle shaft too???? The person before me used the wrong castle nut thence I can't distinguish from any nut markings?? Also I asked Moss Motors but they weren't able to inform me whether it might be either 5/8th or even 3/4"S shaft.. YEA might need to rethread that shaft then??? But am certainly a novice regarding this entire operation???? Yes stuck between being able to rethread and afterwards then finding that right castle nut too???? Please do Help???
About taking this part to a machine shop: I'd forget how I origjnally tore everything apart in order for them to correct it????
Take a picture of tear down, reverse to put back.
