LED Ceiling lights
Administrator
Boss
Has anyone here installed those very thin LED ceiling lights with the attached junction boxes?
I have… quite a few
Ensenior 6”
I have… quite a few
I’m thinking about installing maybe four of them in my newly remodeled bathroom ceiling. My concern is that, while I have a pitched roof, I have unfortunately no direct access to the space above the ceiling. I’m hoping I’ll be able to figure out a way to route the Romex from the switch up to the lights without having to cut too much additional drywall for access.
Was routing the wires, a problem for you or do you have access to your space above the ceiling?
Was there existing lights?
Wild suggestion….
Mount the boxes close to the switch and cut the male plug off of the light fixture.
Then snake 24 gauge wire from the LED to the male plug. In essence, you are extending the wire from the LED to a more accessible place for the box. It should be lots easier to run 24 gauge wire.
I didn’t have to run wires. I replaced existing recessed lights so all I had to do was remove the old fixtures and install the new LED fixtures.
Wild suggestion….
NA, I’m gonna just run Romax up to the box and wire up the connections in the junction box that’s provided. I just wanna make sure that I’m staying in code.
I too thought about code but I assume that from the box to the LED light has to be low voltage.
Obviously the right way is to run the romex to the box.
Years ago my parents wanted spot lights installed in the middle of the living room. They had an electrician come and he cut the holes for the spots and used an 8 foot long drill bit to connect between the spotlights... no cutting into the wall / ceiling.. just a very long drill bit and good aim.
This might be one of those times that asking a pro could be worthwhile.
Perhaps part of a solution - we are in the midst of some renos at Smit manor. We have 4 bedrooms with no ceiling fixtures. I can get power to the ceiling but really don't want to open the wall. These are all over Amazon
This one is more expensive - but, is CSA approved. The cheaper ones not so much.
But you'd still have to get power to the light fixtures, right?
