That makes sense.The 1900 is 50 per side but all solid state - I beleive it still has the output transformers though but I wouldn't testify to that in a courtroom without verifying it.
The MC30s are 30 each and are a matched pair, purchased together in Radio City, New York in 1957 according to the receipts. The wattage doesn't add up to 80 per side though because when using the 1900 as a preamp the onboard poweramp is idle, since the MC30s use a line level input not a speaker level input. I generaly switch between using the internal power amp of the receiver in the summer, and the tube amps in the winter when the extra warmth is welcome. They do make good space heaters as well as sounding amazing. I have them normally feeding a set of Wharfdale E50 speakers with the 3/4 inch compression driver tweeters, but right now I am using a different speaker pair because one the E50s needs a recone on the woofer (age not abuse).
