GT6 GT6 Fuel Line routing
svtmikey
Hello everyone!
It has been a while since I posted anything, mostly because it has been a while since I worked on my car.
The PO ran rubber fuel lines, which I am replacing, but I am sure they ran them incorrectly.
The area I am most concerned with is the routing from the fuel tank to the frame over (or under) the left half shaft (axle).
It is run under right now but I can't see that that is correct or even safe.
Can anyone give me some advice on this or even better, send me some pics.
Thanks so much!
Here's the best I could do. The lower line is fuel. My car is a late one. Earlier cars were different.
Thanks very much for the pic and the effort!
I am having a bit of a time orienting exactly where this is on the car.
Would it be possible for you to give me a brief explanation?
Line comes straight down from the tank then makes a 90 degree bend and goes along inside of the frame the frame fold. Nowhere over the axle that I can see. I'll try to get a better pic later today. Car is presently on a scissor lift in my crowded garage and access limited.
Tom
