Handbrake Cable Routing
A
Acton51
Hello everyone.
We are reassembling our 1958 BN4. We need to position the handbrake cable.
Unfortunately we have no reference other than the two ends of the cable itself, but we do not know the path it must take.
Does anyone have photos showing how to pass the cable on the chassis?
Thanks in advance.
Francesco
Hopefully these will help. You may notice where the cable passes under the floor a non-stock piece of split fuel line wrapped around the cable and wire tied on to prevent rattles. The rear part just goes to/thru the eye on the rear axle.
Ignore the other thing with a red knob - it's a proportioning valve for the rear disc brake set-up and will not be found on a stock car
