First post.
I just bought a '66 that's incomplete. I'm no stranger to MGs, so I know my way around the naughty bits of an SU, but I'm more of a tree-hugger now, so I'd like to have a car that doesn't pollute quite as much as my other 3 MGs did. I'm also trying to save some money on this build.
Going rate for a pair of SU HS4s with linkages is around $350. I've found a few downdraft Webers in the $300 range. I'm not ready to go Megasquirt, since it involves too much scrounging and fabrication. And I just stumbled across a complete '77 single Zenith with the exhaust manifold and a cat installed for $120. Probably because they're what everyone else is getting rid of when they install Webers. I don't need a really fast car, and my recollection is that even my fastest MG still wasn't a fast car, so I'm wondering if these might be a good option for me.
Is this something I can put on a stock '66 engine?
Does it need a smog pump and the associated air fittings?
Will the performance be terrible?
Would I lose a lot of resale value by going with something non-original?
Are there other more modern carbs (or even FI throttle bodies) that can be installed on this manifold?
Would it actually help with the emissions?
Any help with this is greatly appreciated.
Hi Guest!
