Nash Metropolitan--It is British--you know!
Harold
Restored a "58 Met--engine---tranny--new interior--brake system--black and white paint-great fun--
great fun indeed - gotta love a Met!
Nice! (y)
And how fast will it go? I talked to a guy at a show that had one and he said he never went over 55mph.
early met "A" 1200cc 4:55 diff--engine really screaming at 55-----Later Met--1500cc 4:22 diff--a little better!!-
Some owners installed a little "hotter cam" duel carbs--3:90--great for hi-way--I live in the Oakland Ca hills--1 mile
uphill all the way to my house--A friend with a Met--3.90 diff--had to use 1st gear all the way up 10-15 mph all the way!
Bring it to the UBSCC British car show in Dixon, CA next year. Show is in MAY, I think the 21st next year. You can watch for info at:
UBSCC.org
If you go to u tube and watch GOODWOOD VINTAGE RACES you'll see one racing and while not blowing the Jags etc off does function well.I guess it's limited to the anemic carb it came with~~! I think it can upgrade to 4 CR speeds, sprite disks and a header if not the bigger SU's It probably doesn't weigh much more then a sprite so with 1500cc's can stand a chance!
Well done!
Mets neither go nor handle decently but both can be remedied.
IIRC they can use BMC A series diffs, but a B series axle is more durable (Riley 1.5 also use the Midget A series diff with a 1500 engine but if you start hopping up the engine you can snap axle shafts). Check the Metro sites to see what the best front disc brake set up might be.
I owned a Riley 1.5 and seriously looked at putting one of my MGA Twin Cam motors into it!
