Bob, the bell housing is mine as is the throw-out lever. Never had issues with them before. I don't know if the mechanic replaced the release bearing.Your first set of photos shows considerable heat damage and some scoring on the contact plate for the diaphragm; these usually don't wear against the relatively soft graphite bearing. Did you get the bellhousing and throw-out lever from the seller? Did he try to jury rig a ball or roller bearing somehow?
That damaged area should not be there. Compare to my input shaft.I haven't worked on a Healey transmission for over 25 years (I run a Toyota) so I may be way off but that doesn't look like damage to me. It looks like a deliberate part of the shaft - these are hardened shafts and simply rubbing on something would not produce that smooth radiused reduction in diameter. Add to that, there is nothing in that area inside the pressure plate for it to rub on (and there is no heat discoloration from friction showing).
History, DW heavy duty clutch installed 10 months ago when I had the engine rebuilt. I remember now, the release bearing is new and replaced as it was part of the DW clutch kit. Has only 200 miles on it, being I'm doing test drives trying to figure out what's wrong with my transmission, which you'll find me dominating the forum about. The clutch fork in the bell housing works easy and smoothly. Why is the release bearing glazed from heat.The first photo of a release bearing in your series looks to be glazed from heat. This isn't normal; no captions so I don't know its story.
