TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6
TR6Canuck
Hi gang,
I want to buy spoke wheel rims for my '72 TR6.
I currently own Michelin Redline tires. They have TUBES. Tire size is 185-15.
Q1 - What size chrome spoke wheel rim do I purchase?
Q2 - Moss sells MWS spoke rims that say they are TUBELESS. IF I purchase those spoke rims can I install Michelin Redline tires with TUBES, if I also use Rim Bands (to prevent spoke nipple ends from chafing tubes)?
Would really appreciate any sage advice
Rich
Administrator
Boss
Rich,
You posted your question in our โ€œForum Helpโ€ forum, which is intended as a place to ask questions about navigating this site.
If you are reading this, you are in the Triumph forum (I moved your post but will leave a pointer in the original forum).
TR6Canuck
TR6Canuck
185-15 tires. Couldnโ€™t see any specifications on the current rims
malbaby
Hi Rich......Personally, I would either keep the nice looking current rims that you have, or change to Minilite style mags.
Wire wheels are a lot of work to keep clean, and not as strong as steel or mag. Most current reproduction wire wheels have inferior chrome.
[You can still fit tubes and bands to any wire wheels].
Andrew Mace
Yikes! That's what I was afraid of. The last three digits are the manufacturer date; before 2000, it was only three digits, the first two being the week and the last one being the year. So your tires were made the 31st week of 1999, or maybe 1989, or perhaps even 1979.
Bottom line: Save these for display if you like, but don't drive on them! You could get lucky; more likely, they will fail at a bad time, risking your car as well as your life and that of others! Modern "rule of thumb" is six years for tires (some might stretch that to ten years). But since yours are 22 or 32 or possibly even 42 years old, it ain't worth the risk!
TR6Canuck
TR6Canuck
Appreciate your advice Andy, many thanks. Amazing that tires that old still look so good - tons of tread, no cracks. Any advice where I can buy new Michelin Redlines (they are not easily found online)? Or, since I don't drive the car aggressively, will Coker Redlines perform sufficiently?
RGK
I have original Michelin Redlines on wire wheels for my 250. I replaced them due to the tires age with Universal Sports on alloy wheels. The wire/tire combo are sealed in bags for posterity.
RGK
beautiful look Ralph, nicely done!
Thank you. The wheels are from a fellow in British Columbia, a replication of the ARE magnesium wheels offered on the 250.
On the car with center caps.
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
Marvin Gruber TR5/TR250 TR250 wire wheels, 60 or 72 spoke? Triumph 6
D new member with spoke wire wheel questions Triumph 12
T 60 spoke wire wheels Triumph 17
W Will 60 spoke wire wheels fit 100-6 ? Austin Healey 10
Tinkerman Wire Wheel Spoke Removal Triumph 4
F Caliper to wire wheel spoke clearance. Austin Healey 12
B TR6 Dunlop 72 spoke wire wheels TR6 Triumph 6
Tinkerman Spoke Length, 60 Spoke Wire Wheel Triumph 5
G Wire wheel leaks at spoke Jaguar 10
B wire wheel spoke tuneing Austin Healey 8
D 48 spoke wire wheels AH MKI, What to do with them? Austin Healey 11
tahoe healey wire spoke wrench Austin Healey 1
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
B TR4/4A Wire wheel question Triumph 10
F I canโ€™t remove Wire wheels from new hubs - help Austin Healey 43
T Location of ground wire for BJ8 Austin Healey 6
C What to do about my wire wheels Restoration & Tools 6
P TR5/TR250 wire wheel question Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
