It seems to happen all the time but I got the cart before the horse again. The passenger side inner wing flange was tacked in place and there was a small section still to repair.
This is the section that still needed to be repaired.
This is a paper template for the repair to be cut to.
I missed a photo of the repair in place clamped so that it can be scribed and cut out. I don't cut away the old until I have the repair cut and ready to replace the damaged area.
The entire flange has been replaced on both sides, the other side is already done, not really sure why I left this side tacked but all welded and finished now, Still have the cage nuts to install before the B post goes on. The B post is prepped and ready to be welded as soon as the cage nuts are installed. Frank
