Hello! 1962 TR3B TCF794L - parked in a garage in 1973 and not moved since. This was my uncle's car and it has 59k original miles on it. Originally black with red interior, it was repainted at some point pre-1973 to BRG with the intention of changing the interior trim to black (new reupholstered seats never installed). I looked over the car with a British sportscar mechanic and he suggested it's one of the best (semi) original cars he's seen. There is very very little rust on the frame, rear springs, etc. The rockers are solid. Some pin holes at the front of the driver's floor pan - the rest is very solid. All panels fit nicely, gas tank was emptied and no sign of anything in the tank. Batter box in fine shape. I will be doing a mechanical resto on this car to get it safe and drivable and then worry about cosmetics, etc as time and money allow. I have a couple of questions for anyone who can give me some suggestions . . . .
1. How to outline this project. There are SO many different systems to address and I am very handy but have limited experience on cars. I understand that basic things like rubber, brakes, will need to be addressed. The engine will be rebuilt. Beyond that I am not sure how to prioritize the different projects in order to get it safe and roadworthy - and I don't want to pester my mechanic with too many newbie questions. Any work I can do myself I will attempt with limited time, but not adverse to paying for the important things like maybe the front suspension? Just looking for some linear post-engine rebuild suggestions on timeline/priorities.
2. I purchased a used (very good shape) set of 165/15 Federal VW tires to replace the 50+year old tires - my intension was to use these as rollers to get the car safe, but they are in great shape so I thought I could use them to drive on. The installer said since the original steel wheels are riveted and not welded he wasn't sure tubeless tires would hold properly so we are installing tubes. I researched tires for this car but must have missed the part regarding tubes. Does this car require tubes and if so will any of the typical 165/15s work with tubes or is there something specific I should consider?
3. Paint - I will not be repainting this car. The existing paint isn't terrible, I believe I'll be able to buff it to a reasonable finish while working on all the cosmetics. Howerver there are some deep scratched, 1/4" chips etc exposing bare metal. Wondering if anyone has suggestions for how to best touch up these so as not to make the existing paint worse. I'd prefer not to sand/primer the car in places - I think that would look terrible - but if it's the only way, ok. Or can I touch up?
Thanks for any input I am really looking fwd to getting this car drivable.
PS, I understand there are two camps on pulling/rebuilding the engine vs "firing it up" and I will be pulling and re-building the engine. I'd appreciate not opening a can of worms on that discussion.
