For regular readers of BCF, you know I’ve been having starter problems lately. To recap, after a run in the car which brings it up to temperature, the starter will not crank the engine. The starter motor turns, but the crankshaft does not. Pre-60k with press-on ring gear. Hi-torque Starter (with a 9-tooth cog) replaced, I directly grounded the battery to the block, and it has a fresh battery. Those were the logical, obvious fixes. I went out today to continue to diagnose, thinking it’s a bad spot on the ring gear (to test the theory that the engine has a preferred stopping position. The car started right up cold (Mind you, yesterday after a wam-up run it wouldn’t) After a quick drive around the block to bring it up to temperature, I turned the ignition off and used the clutch to “force“ it to stop in another position on the flywheel. Popped the clutch, so to speak. Anyways, no change... starter motor is turning but not the crankshaft.
BUT, in a sign of at least diagnosing progress, I turned off the ignition switch, immediately turned it back on, and the engine started (Of course upon pressing the start switch). THIS sequence I was able to duplicate a couple of times. I captured the sequence on video, but of course the file is too large to attach. FYI, On the other side of the engine I run a Pertronics in a Mallory distributor.
This all started after the engine was laid up for about two years when the body was off.
Any ideas? I’d be happy to send the video separately.
Oh, how I miss Randall!
Jim
TS44067L”O”
Jim
TS44067L”O”
