TR2/3/3A Wiindshield - top rubber seal.
Tinkerman
I hate to admit this, but I made an error when I re-assembled my windscreen. I cut the top seal a bit too short, sigh................
My question is, can I replace the top rubber seal with the windscreen in place or is it a bench project?
I assembled it all so long ago I don't remember. It looks kind of bad now and since it sits out there in font of god and everyone else, I feel the need to replace it.
Your thoughts and ideas are greatly appreciated!
Thanks, Dick
Dick,
its not a hard job. Think you can do it without pulling the w/s off but worst case its only three screws on each side to left it out.
Marv
Geo Hahn
I see no reason why it cannot be done with the windscreen in place. Use lube (dishwashing soap) and usually pulling it stretches a bit to make it thinner for easier fitting.
...I cut the top seal a bit too short, sigh................
The problem may not be that you cut it too short - but rather that it shrank. Rubber does that - so does the 'chrome' locking strip on a TR4 windscreen. It can take it a long time to finally stop shrinking so if there is any way you can leave it a bit long for awhile it might be a good idea.
CJD
If you are talking about the very top, then the lip is rather long. The only way I have been able to install it is by sliding up along the side, from one of the bottom corners. Of course, to do that you must undo the 3 chrome screws along one of the stanchions and remove the stanchion and tenon plate. That should be doable on the car...as long as you protect the scuttle from the weight of the assembly with one side removed.
Scroll this page down to post #157 and it should revive your memory:
https://www.britishcarforum.com/bcf/showthread.php?108693-Recipe-for-a-TR2/page4
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
S TR2/3/3A new Robbins top Triumph 11
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
EWD TR6 TR6 top dash trim paint Triumph 2
