TR2/3/3A Where did all my TR3 bottom end power go?
jsneddon
I have been staring at this problem too hard and now I can't see the forest for the trees. Hopefully some of you can point out something that will make me slap my head and say DOH!
I have a TR3 that sat for 10 years. Prior to parking it I had rebuilt the head. After the rebuild I had about 130psi per cyl. and it ran like a scared rabbit for 6 months until I put it in storage.
I got it running again about 2 months ago. But it has no bottom end power. Above 3000 it feels pretty "right" but getting to 3000 feels gutless when I put my foot in it - not even under load. Under load I could barely get it up the hill around the block at full throttle in first gear. On flat spots it will get up to speed but it doesn't feel right.
Depending on where I set the advance I get a good deal of sputtering and coughing back out of the carbs until it gets up to 3000. I can "ease it" up to 3K but if I put my foot in it it sputters and coughs.
Here's the facts:
* Rebuilt Carbs
* Dashpots rise equally, don't seem to be binding, airflow is balanced.
* Mixture seems to be OK from the "lift the pin" method. If I crank the jets up or down I get the appropriate "speed increases" / "speed decreases" response. Currently the jets are set so that I get no change when lifting the pin
* Floats are filling up appropriately
* no vacuum leaks found with a liberal hosing of carb cleaner while running
* New Points, Condenser, Coil (I just threw all my spares at it in a fit)
* Static timing has been adjusted 6 ways to sunday - 4 degrees, 8 degrees, timing mark at the mark and dialed in, timing mark 3/8 inch and no dial in, etc etc etc.
* distributor wieghts and springs are free and clean and move
* vacuum advance pipe is clear and connections are good
* new spark plugs - plugs that had sat in the car were black
* everything from the tank to the carbs has been flushed - after 10 years it was completely clogged.
* brakes have been completely rebuilt and nothing is dragging.
* oil changed
Here's what I'm going to try next:
* I'm going to floor it and shut off the car - see if i'm missing fuel in the floats- I could see where I'm still getting gunk in the lines but that doesn't make too much sense to me since it runs better at high revs - I'd think fuel starvation would be worse at higher revs.
* Dashpot oil is currently ATF (it was what I had on hand at the moment I needed some) - I'm going to replace it with some 30w I guess.
* pull spark wires one by one and see if I get the same change on each.
* I haven't checked the valve clearances lately - I reset them about 4 years ago when I was trying to get it to run but life got in my way again.
* Get a timing light with an advance and try the suggestions on the previous TR3 Ignition Timing Help thread.
* replace my missing compression tester and see where I'm at today.
Any other suggestions/tests/ideas would be appreciated.
Thanks!
Geo Hahn
I certainy concur with pulling plug wires one by one, checking valve clearances & a compression check.
What you describe sounds like you might be running on 2 cylinders -- this could happen if you have a stuck needle (or grose jet) in the fuel bowl but it sounds like you checked that already.
At the risk of suggesting the insultingly obvious... have you confirmed the firing order is 1-3-4-2? The 3 & 4 wires can get switched if they are long enough.
jsneddon
jsneddon
Geo... I'm never insulted by someone pointing out the obvious. This was exactly the second brain looking at the problem that I needed.
My firing order was set to 1-2-4-3... I had the two middle wires switched !!!!!!!!
Attaboy Geo!
swapped them and now it runs like a scared rabbit again!
I owe you a beverage of your choice /ubbthreads/images/graemlins/smile.gif
THANKS !!!!!!!!!!!
TR4
How does Geo do it? I think I owe him a 6 pack by now with all he has diagnosed on my TR4. Makes me believe he could lay his hands on a TR and it would fire right up!! /ubbthreads/images/graemlins/cheers.gif
sammyb
Maybe we can get Basil to sponsor a "BCF Member of the Year." I definitely think Geo is top contender!
Geo Hahn
[ QUOTE ]
My firing order was set to 1-2-4-3... I had the two middle wires switched...
[/ QUOTE ]
The ignition wires on a TR3/4 can be trimmed such that they can only be connected to the correct cylinders (e.g. you could still connect 3 to 2 but 2 would not reach 1, 3 or 4 and you would know it was wrong).
jayhawk
Hey, maybe we could make Geo "the Fonz" of the LBC set-- 'Cept he can lay hands on thru cyberspace.
B TR2/3/3A Where did I see the picture of the TR3 bulkhead Triumph 6
warwick-steve Where did the smell go? Austin Healey 11
R Where did it go? A who-done-it mystery! Austin Healey 18
Jim_Newman Where did I go wrong? Austin Healey 37
M where did it go Triumph 2
T where did my coolant go? Austin Healey 5
M Where did my horn go?? Spridgets 4
KVH Where Did They All Go? Triumph 5
Stewart So where did you take your B today? MG 6
mgblue79 Where did the summer go? Spridgets 23
jlaird Where oh where did Jaybird go? MG 51
S T-Series Where did my clutch fluid go... MG 7
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
