What's a "Restoration?"
My thoughts so far, in no particular order:
Types of "Restoration:"
- Earl Sheib Paint Job and Tire Gloss: 'Nuff said
- Cosmetic: Body remains on chassis. Structural rust cut out and replaced (quality of work varies). Surface rust is treated or sanded and painted over. Dents may be beaten back to near-original shape, then filled. Rubber parts replaced. Damaged, pitted windshields replaced. Undercarriage largely neglected (except for serious structural rust or other problems). Suspension components only renewed or replaced if absolutely necessary. Drivetrain--engine and transmission--left untouched if working reasonably well. No attempt to repair or refurbish original parts if new substitute available. Interior replaced if original not presentable (no attempt to retain original aspects). Glossy but not necessarily quality paint. This is typical of many of the 'quick flip' shops that are (apparently) so popular on TV (are they all in Texas???).
- Driver: Drivetrain overhaul. Only minimal safety, drive-ability and maintainability repairs or improvement. No significant improvements to appearance or comfort.
- Cosmetic Driver: Cosmetic Restoration with drivetrain overhaul.
- RestoMod: Cosmetic Restoration with significant modification. Drivetrain replaced (almost always with some form of SBC, 9" Ford diff, etc.). Interior replaced with over-the-top finery, new gauges, etc. Intensely shiny paint job with at least 6 coats of clear, with or without metal flake base coat.
- Tribute Car: Form of RestoMod. Standard, common variety of vehicle is 'upgraded' to specifications and appearance of special editions or otherwise uprated versions of same vehicle. Examples: Chevy Nova/Chevelle 'SS,' Tempest 'GTO,' Austin-Healey 100 '100M,' etc. Usually honestly represented by 'restorer' initially, after changing hands several times buyers may be led to believe--unintentionally or otherwise--that vehicle is actual original version, and not a clone.
- Driver Frame-off: Frame off, nut-and-bolt, with little or no attempt to retain original nuts, bolts, trim, etc. Contemporary fasteners replaced with modern SAE equivalent. "If it's broke, buy a new one." Concessions to "get 'er done," but essential essence of car largely retained. Modifications for drive-ability and maintainability (electronic ignition, spin-on oil filter, 4-wheel discs, LSD, hotter cam, etc.).
- Concours: Frame off, nut-and-bolt, with every attempt to retain original nuts, bolts, trim, etc. Fasteners re-coated in zinc, cadmium or chrome as required. Drivetrain restored to original specifications; no attempt to increase HP, torque or noise. Original interior repaired and refurbished if at all possible. All body and drivetrain ID plaques and stamps preserved. Seams and dents are lead-filled, if originally done at factory; otherwise, only minimal use of filler allowed. Paint as original (usually, one-stage lacquer or enamel).
- Survivor: Barn/garage/pond etc. 'find.' Only enough mud/dirt/oil/sludge removed to reveal major components of car. Rust only treated to halt spread (think USS Hunley, or the Bugatti(?) someone recovered from a lake). If condition warrants, engine and drivetrain refurbished just enough to get running. Usually sold at auction to be turned into RestoMod. Sometimes, inherited from relative, cleaned up, return to running condition and driven.
Obviously, most 'restorations'--with the exception of Concours and Survivor--are some combination of the above. No opinion or judgement offered or implied; "it's your car, do what you want with it."
MisterB
"Restoration" to me has always meant bolt head and paint mark totally factory-correct. No clear coat on older cars, no added chrome, no upgrades. Anything else is different levels of "Fixing up". I really admire restorers. I live on a sand road, though. Nice driver is my goal.
Mike Burgess
Albert, KS
simon1966
Since this is a Healey list, I can't help but feel that there should be a special category for "M"ing a standard 100?
Bob_Spidell
Or "SS"ing a Chevelle or Nova, "GTO"ing a Tempest, etc. We used to call these 'counterfeit,' but they've undergone an image makeover and are now 'tribute cars.'
Added as 'Tribute.'
Mike Tobin
Started closer to Concours than Driver Frame-Off. Then I discovered McMaster Carr. Screw cleaning the original screws! I'm now firmly in the "If it's broke buy a new one!" SS ignition, alternator, gear reduction starter. However, the original SU fuel pump will still be clicking when I die.
A 100/6 BN4 Restoration Austin Healey 5
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Greg Chait Wanted Stalled or Abandoned MG Restoration Projects MG Classifieds 3
H General MG MGYB--Semi-- restoration MG 2
D My new restoration tool Restoration & Tools 13
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
JoeO 72 TVR Vixen hybrid restoration TVR 1
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
D Fascia Restoration Austin Healey 14
J Restoration Progress - Boot Installed Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Tr4 restoration books Restoration & Tools 2
F YouTube Healey Restoration Videos Austin Healey 5
R TR2/3/3A Re-start after total restoration Triumph 22
F GT6 Looking to sell - in progress restoration Triumph 19
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
Don Riicardo Reliant Scimitar GTE se5a restoration Other British Cars 23
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
C SoCal Restoration Shops Austin Healey 15
HealeyRick Coronet Cream Restoration Austin Healey 1
H Restoration Magazines and Books Spridgets 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
Got_All_4 TR6 Starting my frame restoration Triumph 32
F General MG Field find restoration question ... MG 5
R TR2/3/3A Restoration of 54 TR-2 Triumph 6
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
S TR2/3/3A Frame off vs. body on restoration Triumph 21
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
V TR2/3/3A TR3A Chassis restoration Triumph 8
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
A TR2/3/3A Restoration work near San Diego CA Triumph 2
JPSmit Restoration on a Budget Restoration & Tools 4
F Restoration Guide Austin Healey 2
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
T General TR Ron's Vintage Auto Restoration - Salado TX Triumph 2
C Looking for SoCal restoration shop Austin Healey 4
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
J TR2/3/3A Starting my TR3 A restoration Triumph 8
