TR6 What holds this TR6 headlight switch in place?
tomshobby
Looks like that could be a picture of the back of my dash when I took it out. My car's PO must have replaced the switch at some time and had wound black tape around the sides, top, and bottom until it fit snugly in the opening and stayed in place.
Thinking that that just was not acceptable I ordered a new switch and found I had the same problem as the PO had. Realizing that I would have never known the difference if I had not pulled out the dash I got out my black tape and until I wrote this no one would ever have known. Besides it works perfectly.
But, I too would like to know the answer to this mystery.
2wrench
2wrench
Great response! Laughed out loud a few times on this
one.
I'll have to wait to see who else will weigh in on
this baby.
2wrench
rotoflex
I am not very familiar with TR6's, but that is a common BL switch. Also without a y/m for the car, it is hard to be specific. That type of switch was held on by one of two ways:
1. A framing plastic piece that went in the front of the dash, into which the switch was snapped (part number 148437)
2. A rectangular metal framing piece screwed to the back of the dash into which the switch snapped when inserted from the front. That may be the remains of a metal retainer broken to the right of the hole in your picture.
You REALLY need a parts manual for your car, as it includes assembly diagrams for everythin on the car. You can get one on CD with a shop manual from the Heritag Motor Centre:
https://www.heritage-motor-centre.co.uk/shop/technical-publications/triumph-tp/index.html
2wrench
2wrench
Yeah, thanks. Actually got a manual. Figured if vendors
couldn't find the part, no use for me to go looking.
I do see a box looking item, but it is not showing
available from Moss; Vicotria or TRF, so not much
good. Guess I have to get creative.
Appreciate your time and trouble,
2wrench
G
I concur...black electrical tape is the only solution to aftermarket light switches. But remember, this is an unfused circuit, where all the amps from your battery are sitting right there in your dash. I put some heat shrink tubing pieces over each Lucar connector to stiffen them a bit, connected them outside the dash, carefully wrapped the connectors in place, wrapped the housing for the tight fit, then re-inserted.
backroadsjeff
I was very interested in the response because I have the same issue, the PO had put electrical tape around the switch to attempt to hold it in place, but it keeps creeping out. I guess I'll wrap some more on, because the switch works fine, and I have bigger fish to fry like why the spedo doesn't work!
rotoflex
The little metal plate on the back of the dash is typically a JY item.
Andrew Mace
This might help some. It's from the Rimmer Bros. web site.
"The original 'Clear Hooters' manufactured switch was the subject of a factory recall in the United States. The replacement that was fitted by the dealers was a 'Lucas' item. The 'Lucas' switch has a larger body than the 'Clear Hooters' so the steel retaining plate that is screwed to the back of the wooden dash was either filed larger or replaced with a plate having a larger switch hole. The 'Lucas' switch has an integral non detachable escutcheon."
The recall also affected Spitfire and GT6 models from 1969 on. If I remember correctly, the modifications required to fit the Lucas switch in place of the Clear Hooters switch were slightly different for these cars. From what I can see in your picture, there's virtually no retaining plate left, which would explain the need for electrical tape!?
rotoflex
Wow, I remember that. The original Clear Hooters switch broke in the plastic, & the improved Lucas version required a different plate. I got a replacement plate from a jy.
I also remember going to the BL dealership when it broke, about 1977 or 1978, showing them the problem, & they sold me a new switch while trying to sell me on having them install it. Never a word about the recall, which I found out about around a year later. Behavior typically reported of dealerships for any cars in the US.
TulsaFred What holds the rear wheel and axle on? Spridgets 6
J The nut that holds the steering wheel boss Austin Healey 6
D What holds the cam in place? MG 4
kindofblue First PO hack repair holds up project Triumph 1
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
