Wedge Triumph TR8 Vibration Damper
JodyFKerr
Hey Folks,
I'm wondering if y'all can help me. I'm looking at the diagram in my
TR8, manual for the Crankshaft Vibration Damper. In the diagram there
are two versions, one which shows three pulleys and the other that
shows 2 pulleys (I presume the difference is AC vs Non-AC cars).
There's also a funny plate (602587). The final part is labelled with a
designation of NSS.
I've double checked against a VB catalog I have here on hand, and the
only part they sell is 602587 which they describe as a reinforcing
plate. Is this the rubber sandwich plate that needs to be replaced? or
is the harmonic damper the oddly shaped item designated NSS?
I've finally got my alternator pulley and water pump lined up
correctly, but the pump is still squealing, so my thought (which was
followed on by a separate recommendation) was to look into replacing
the harmonic dampener.
Thanks in advance! I'm trying to get all this sorted before Triumphfest!
DNK
Did you replace the damper or get it rebuilt?
DNK
Damper,after rebuild from Damper Dudes
Full pulley set up (Pic from Ted)
JodyFKerr
JodyFKerr
Don,
Thanks! That's what I thought, but the *%(^(# TR8 manual and parts catalog was completely useless in that regard. That is, unless I somehow missed the instructions on how to use the little Orphan Annie decoder ring correctly.
You think these guys might stock one of these? How fast was their turnaround?
Jody
DNK
a week plus.
Can't quite remember what it was
JodyFKerr
JodyFKerr
dang, that's not going to work. I need to get this stupid pile of iron running in 16 days....
Looks like I'll be calling the usual suspects first thing in the AM.
JodyFKerr
JodyFKerr
Well, it's the last culprit in the system.
I finally got everything else lining up correctly, but my timing seems to be shifting and I can see a wobble in the two end pulleys on the crank shaft.
DNK
They are in Ca.
Call them. Their web site sucks
DNK
You sure it's not the dizzy causing the timing flux?
JodyFKerr
JodyFKerr
Power steering pump pulley is nice and stable. There's a brand new PS pump on the car. The crank pulleys, however, appear to have more play in them than yours does.
DNK
Now that I look at that.
That was right after I got it.
I had removed the A/C and was hearing funning sounds that's when I saw the bad wobble on the PS and removed it.
The last 2 times I have put the motor together I put the alt pulley next to the dampener.
According to that vid it is suppose to be out more. After the AC pulley.
I guess I have not been lining them up.
I wonder what stress I have been putting on the water pump
Tomorrow I am sure Todd will chime in.
He's a heck of a lot smarter than I am .
Dale
Hi Jody!
Sounds like your getting a handle on this, thought I would chime in with what nothing I know. NSS=Not Sold Seperately. I think
tr8todd
It's not uncommon to see wobble in the crank pulleys. They get bent up fairly easy. Use a run out dial indicator and straighten them out if you can. Make sure your balancer is TR8 and not one from an old Buick 215. The TR8 ones are zero balanced and are interchangeable. The old Buick engines were externally balanced and those balancers don't play well with engines they didn't come from. Recently pulled apart a friends 4.0 that had a Buick balancer. Bearings were shot after 5K miles. Any play in the timing is mostly surely associated with either the distributor or more likely the distributor drive gear. Pull the distributor and check out the gear on the end for wear that looks like knife edge machining. Then look down the hole in the front cover with a flashlight and check out the gear on the end of the cam. The gear on the cam is the softer sacrificial metal. That is the one that is most likely damaged. Had that problem many times on the race car. It would show itself first as misfires at higher RPMs. If your stuck for a balancer and pulleys, I can lend you one, but I probably won't sell them outright. They are made from unobtanium. Send me a PM if you want me to drop one in the mail for you.
JodyFKerr
JodyFKerr
Thanks for the tips Todd.
This car is going in to the local brit car shop. I have neither the patience nor the desire to work on it right now. With all the hassle this car has given me I am very tempted to give it away.
Some cars just have bad mojo.
tr8todd
That's because it came fuel "infected" from the factory. Us four barrel guys never have these issues. We turn the key and go.
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
GBRandy Wedge Triumph Production Numbers [TR8 related] Triumph 26
Pete_Chadwell Wedge Triumph TR8 For Sale Triumph 0
philman Wedge Triumph TR8 on PDX Craig's list Triumph 4
PATR8 Wedge Triumph TR8 Tires Triumph 11
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
KVH General Tech Making the Triumph Engine Dolly Triumph 4
