Airfix
Member
Hi,
Iv'e just bought a 190 TR8, the temp gauge does not work.
The car came with a couple of old temp sensors and 2 other gauges. The PO has obviously tried the obvious fixes with no luck.
Any ideas? I plan on doing a continuity check of the wire from gauge to sender, apparently there is no voltage stabilizer in the Tr7/8. Is it possible that the circuit board in the instrument panel is u/s?
Appreciate any commetns or suggestions. /ubbthreads/images/graemlins/confused.gif
