The left low beam blows its fuse when turned on. It continues to blow its fuse with the headlight pigtail disconnected. The wiring diagram shows the remaining blue/pink wire running uninterrupted to the fuse box behind the glove box. The actual blue/pink wire is contained in a harness that appears outwardly to be in very good condiltion. I have not been able to move the fuse panel through the opening at the rear of the glove box. Is there any way to access the back of the fuse panel without removing the entire dashboard? Can the fuse box itself be dropped down from behind the glove box? Surprisingly, the diagram shows no headlight relays. Anybody have any experience with this problem? If not, I will probably begin removing the dashboard tomorrow.
