Wedge TR7 5 speed differential
Lawrenb
Does anyone know where I can obtain a new "collapsible pinion shaft spacer" for a TR7 5 speed differential? The BL part number is UKC979. If not, is there a work around?
TR3driver
Great Pumpkin - R.I.P
Wow, must be pretty scarce. I found one that sold on eBay for almost $70!
https://www.ebay.co.uk/itm/TRIUMPH-...R-NEW-Original-Rover-V8-SD1-etc-/231057332643
Alternative I think would be to machine a solid spacer and add shims as necessary to get the right preload. But I've not tried doing that for a TR7, so no idea how hard or what dimensions, etc. A good start would probably be taking the old one to a machine shop and asking for a solid duplicate that is .010" or so shorter. Shim washers are available in a variety of sizes from suppliers like MMC
https://www.mcmaster.com/?m=true#round-shims/=r099hs
titanic
Another possibility (although I have never used it) is to use a shim in addition to the collaspsible spacer. When the pinion is re-torqued, the spacer should collapse further to provide the correct pre-load. It probably too late now, but some people deal with the collapsible spacer used on the TR6 by marking the location of the pinion nut before removing, then returning it to the same location on re-assembly.
Berry
titanic
On second thought, scratch the first suggestion in the above post. The technique works with the collapsible spacer that is used to set end play in the rear hubs, but will not work with the pinion which is pre-loaded.
Berry
WedgeWorks
What some guys do is remove the one you have put it over a socket and hammer the bulge down to make it longer to reinstall and be able to be compressed with the proper tension.
tr8todd
Those things have been unobtanium for a long long time. I've reused them with great success. Mike's procedure above is spot on. Other than that, rebuilding is just like any other rear end. You won't get the bearings off the axles without a bearing puller, and you need an inch pound torque wrench. Others have made aluminum spacers, but that requires paying a machinist to make it. In most cases the side shims can be reused without changing them to different sizes, it's just the pinion bearing making all the noise. You can also research Rover SD1 rear ends. They are one and the same. Available gear sets were 3.08, 3.45, and 3.90. There were also 2.84s in some SD1s, but those are hens teeth.
DNK
Guy in UK offered me one on this forum the other week.
Not in a good time money wise.
I also thought the Ford could be sought for comparable dollars
WedgeWorks
I just measured my NOS collapse able pinion shaft collar/spacer and it is .75" in overall length.
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR7 5 Speed Swap? Spridgets 4
D Wedge Speed Bleeders for TR7 5 Speed Triumph 7
boxofparts MGB TR7 5 speed in MGB MG 9
D Wedge TR7 High Speed Rear End Triumph 6
Howard_The_Duck Wedge TR7 5 speed values? Triumph 2
johnrip Wedge tr7 5 speed clutch replacement Triumph 1
M Wedge Trans Oil for TR7 5-Speed ? Triumph 7
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
