TR6 TR6 Turn Signal Cam misaligned
Herald63nut
Gents
My '72 TR6 turn signal cam is misaligned, or rather the steering column is off. I am not sure how to go about realigning the steering so that the turn signal cam does its job post-signaling and completing the turn. Thanks for the help.
M_Pied_Lourd
Nut,
not sure if this helps, but bobby d has some good pics on his website of the steering column and the cancelling clip.
https://tr6.danielsonfamily.org/SteeringColumn.htm
You might be able to check and see if you cancelling clip has moved or is not set up properly.
Cheers,
M. Pied Lourd
trrdster2000
Herald, take the steering wheel off to check for alignment. If you need to move the shaft to get the tab centered. take the shaft loose at the bottom "U" joint, next to the rack, and move into place. It's just a crimp connection and should slide out of the way with a little help from a flat punch.
Wayne
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
hondo402000 TR6 Turn Signal Issue on 71 TR6 Triumph 4
hondo402000 TR6 resteting the turn signal canceller TR6 Triumph 11
trbob TR6 TR6 TURN SIGNAL ISSUE Triumph 8
Steve1970 TR6 TR6 - Should turn signal work if hazard is gone? Triumph 8
tr6web TR6 TR6 Turn signal not working Triumph 4
2wrench TR6 TR6 Does not turn over. Triumph 38
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
I TR6 TR6 turn indicator Triumph 1
D TR6 TR6 won't turn over -Rookie TR6 owner Triumph 12
I TR6 TR6 turn indicator not working Triumph 1
I TR6 TR6 turn indicator Triumph 2
H TR6 TR6 turn signals Triumph 15
Webb Sledge TR6 TR6 Turn Signals Triumph 4
Hawk813 TR6 TR6 Brakes Triumph 4
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
