TR6 TR6 Diffy - Dumb ? But Thought I'd Ask Anyway
erstearns
Was pulling out the new Stebro Dual that was temporarily hanging with zip ties and noticed a "too large" glob of gear oil. Seeing that the old girl had been at rest seemed like too much to ignore. The obvious culprit is the pinion seal but the right and left inner axle seals likely contribute also (probably the rear cover seal too!)
The query is this.............can the pinion seal be changed without pulling the diffy? Looks like the inner axle seal housings can be unbolted while in place but not sure about the pinion seal.
Would like to fix the obvious leaks the "easy" way. If it comes out then a rebuild and body mount mod would be in order (needless to say longer, harder, more green stamps).
Can I cheat? :nonod:
Brosky
According to page 51.20.01 of the TR6 manual, the pinion seal must be replaced with the differential (hypoid casing) out of the frame. It does not state the housing must be removed to do the axle seals, but it's probably best to do everything right and on the bench.
Then you can really clean out the junk inside the casing after 30+ years of driving and also replace the housing rubber mounts.
If you need any printed literature for this, send a PM me.
E
erstearns
Thanks Paul, the manual I had never really stated that you had to have the diffy out of the car to replace the pinion seal, but it assumes you would. I was having a hard time determining what was necessary that would require it, other than more optimum working conditions on a bench vs under the chassis. Was hoping to put off the full rebuild of the rear end until I got to the point of a more full restoration. May just live with a drippy diffy on the new stainless until the winter. No other real issues I am aware of except for the leak(s).
billspit
I know nothing about TR6 diffs, but I assume it uses crush spacer on the pinion just like Spits. Once you loosen the nut, the spacer is trashed. I've heard they can be reused, if you are careful to tighten it back the same number of flats that you loosen it. Tough to do in the car. I too would just drive it until its ready to come out for a proper going through.
R6MGS TR6 TR6 Diffy oil....How to? Triumph 17
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
