    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR4/4A TR4A BRG #75 paint code Ditzler 42487
shoopal
Hi all
I posted some months ago with the PPG formula in single stage DCC for this color and it was a exact match but very very expensive.
I just discovered another source which is much more reasonable.
TCPGlobal.com provided an exact match using acrylic urethane $55/Qt and $20/half pint hardener. Even less if you buy A gallon of paint and a quart of hardener.
This is the dark green with a blue tint not the lighter green (#25).
The only drawback (if you are in the East Coast like me) is that it comes from San Diego via ground. Figure on 3-5 days for the mix and another 3-5 days for shipping
Geo Hahn
...This is the dark green with a blue tint not the lighter green (#25)...
The 25 I am familiar with was called Triumph Racing Green in 1964, at other times called Conifer. It is a green with a blue tint. Not something I would call light but that may be relative.
Called BRG on this chart:
I take it that 75 is much darker?
Okay - Maybe the reference to #75 in the subject line is a typo and we are talking about the same thing?
S
shoopal
Here is a picture of the 2 colors put on a background of the vent flap which was the original. 2 pogiveints. The color you see on the screen does not necessarily match what you see in person. Second, shadows and lighting can also give variations. In any case the 75 is the darker one the 25 is the lighter one.
Apparently TR changed BRG somewhere in 1965. The one I was looking for is the #75 and I was quite happy with the TCPGlobal mix. They will supply a sprayout sample for $35 but I decided to order just a quart for $55 to see what is really was and I just completed the follow up order for another 3 quarts. This gallon plus 1 quart of hardener will cover the whole car including the trunk, interior, engine room and the panels under the fenders and wheel wells (I hope).
glemon
I used the TCP global single stage urethane for me TR250 as well (signal red). Probably 1/2 or 1/3 the price of the name brands, worked fine. I think they save the formula they use to mix your paint so if you order more you should get the exact same thing.
PS A gallon was enough for me to paint the whole car inside and out, including a repaint of the doors and a fender because of some self created issues. I ended up buying another quart but once again due to self inflicted issues.
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
T TR4/4A Triumph TR4A 1965 price Triumph 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
