TR2/3/3A Top web and fitting question
bob67bgt
This is my first TR3 top install. Looking at it I would think I set the front bar first measuring from the rear snap on the car to the front seam. Then set the rest of the seams to the bars. Is this correct? How would you do this project? Thanks , Bob I will post a pic soon. There really is a TR in my MG garage!
B
bob67bgt
After some research I found a site that says 15 3/4 up from the rear deck, 8" to the next bar and the front bar sits 4" above a horizontal line from the top of the windshield. Now that I have that done and the rear lift the dot snaps in at the back(not the sides yet) The top appears to be a big stretch to the windshield. Do I mark center and lower the frame and start installing the front snaps? Then hope it will stretch enough to go up and not crack the windshield? I am working with a Robbins canvas top. Bob
bobhustead
Set the rear bar first, then measure and set the middle bar, then the front bar. The top frame relies entirely on the tape for positioning of the bars vis a vis each other and the tonneau saddle. Measurements need to be with the top snapped on and the bars positioned against the top, one at a time, for tightness. The seams don't tell the story.
Bob
bobhustead
PS The top is a big stretch every time you put it on. Make sure it is warm when you lay it out the first time and install the tape. When you put the top on in daily use, the frame is erected under the snapped on top by pulling on the tabs at the base of the rear bar.
Bob
B
bob67bgt
Thanks Bob,'
I guess I will go out and lower the frame so I can install the front snaps. I did try to stretch the webbing since the top would be pulling on it when installed so the lengths would match what I found on line. Wish me luck I'm goin' in. Bob
PeterK
Rather than fit my new top to an old Amco measurement (which I have a print of), I set my frame to the seams in the top. The Amco measurements didn't work for my frame and top.
So in this regard, I would suggest measuring what you've got and making your own diagram. I used a fabric marker/pencil and many tape bits with marks to check and to keep it in alignment as I progressed. You want the frame bows to end up under the seams. I used clamps to pinch the webbing to the bows for adjustment and marked around the edges of the webbing plates with a fabric pencil.
When I finally thought I had it all fine and re-measured a couple of times, I started in the centerline of the car back to front and worked my way from this centerline to each side.
I took my time over a couple of days on and off to get it perfect. It's been staying tight in any weather.
charleyf
You are correct to set the three bars to the three seams or pleats in the top. Just beware of doing this in a cold area where the top will be shrunken and then stretch out when it gets warm in the sun.
Charley
MDCanaday
At the shop we cheat a little and put an electric heater in the car to warm up
the top while it is fitted up(sitting on a fire blanket of course). We also use seat
belt material for the webbing. Make sure that you have a good quality top
before you start,there are some awfull ones out there that can cause you to say
bad things......
MD(mad dog)
A Convertable Top web straps Spridgets 4
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
S TR2/3/3A new Robbins top Triumph 11
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
