YakkoWarner
I now have an engine and gearbox bolted together to form a single unit. I have a complete motor mount kit from Moss (all new rubber and fasteners) which includes replacement bushings for parts I do not even have - the catalog show a rod going from a bracket on the bottom 2 bolts of the engine-to-gearbox to the crossmember under the gearbox. Not sure what that does but it wasn't there when I took it all apart. Thats a problem to solve later since I can't actually determine that it does anything....
My current puzzle is the 2 rubber bushings that go (or more accurently do not go) into the holes on the upper and lower parts of the rear crossmember mount. Is it possible to buy those parts with the rubber peices already installed because I have destroyed several attempting to push the bushing into a hole it cannot fit into (and when comparing the peices of the old ones that came out the sizes are the same, so apparently at some point in the past it was possible to get these parts with the bushings already in them)?
