KLUTZ
Couldn't find the exact answer to this in the search section, so... Neither of the headlights would go up or down when I tried them this year. They worked last year before I put it to sleep. The lights go on though. Well, I found that one wire was not plugged into the relay, the tiny thing, two leads into it. Plugged the one wire in that was off, and the left headlight goes up and down now. The right one still needs to be manually opperated. Question is, is there another such relay for the right headlight mecanism, or do both work off the same small relay? If so, I wonder what the problem could be?
Thanks
Paul
Thanks
Paul
