Switch to Synthetic Oil...Does Engine need to be..
TR3driver
Great Pumpkin - R.I.P
:iagree: Change the filter too.
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
R Bugeye ignition switch Spridgets 2
K TR2/3/3A Old school battery shut off switch....... Triumph 3
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
F Wanted Dipping switch cap Triumph Classifieds 1
L What does this column switch do? Spridgets 4
G Brake Light Switch Failure Austin Healey 24
R Wanted Bugeye ignition switch Spridgets Classified 2
B Headlight Dip Switch Austin Healey 4
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
S Overdrive Throttle Switch Austin Healey 4
SherpaPilot TR6 Ignition Switch Question Triumph 13
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
C MGB-GT Reproduction light switch MG 13
timsgolf Center Dash Switch Plate Painting Austin Healey 5
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
P TR2/3/3A ignition switch smoking Triumph 12
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
6 E-Type brake light pressure switch location Jaguar 5
C TR6 Ignition Switch for 1972 TR6 Triumph 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
algot1901 1950 Prefect Ign Switch Other British Cars 1
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
69MGC T-Series Never thought I'd switch MG 5
jlaird MGB ignition switch MG 2
F Wanted Foot Dipping switch Triumph Classifieds 0
K TR2/3/3A Dimmer switch.....any electricians out there? Triumph 5
M TR6 Mystery Switch Triumph 0
H MGB 1980 mgb no power from ignition switch MG 23
Gliderman8 TR6 Handbrake warning lamp switch build Triumph 14
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
longbridgehealey Bugeye combination switch Spridgets 2
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
longbridgehealey Bugeye ignition switch Spridgets 4
T Bug Eye Heater Switch Help Spridgets 2
A BN1 Mechanical Brake Switch Austin Healey 23
P TR6 identifying switch Triumph 3
P TR2/3/3A TR3B Panel Light Switch Triumph 20
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
