Sprite seat recovery - is there a "how to" guide?
RickB
I've got all my pads & covers now, so where do I find instructions? Drawings? Step by Step? Photos?
These are early Sprite seats.
George Zeck
Re: Sprite seat recovery - is there a "how to" guide?
Rick –
First – no instructions, but why do you need them when you’ve got the BCFer’s?? I did mine about 18 months ago.
#1) A few points up front – the faster you go the more and severe you will botch this up.
#2) DRY FIT EVERYTHING !! You have two seats – and you will get through this. It took me a few weeks to do ALL interior pieces. And now it looks awesome !!
I did not replace the seat padding, your on your own.
For the seats …..
A) you have 2 – slowly study and remove (cut away) the old fabric. Study how it was installed. Duplicate.
B) Dry fit the “arms” – make sure these fit properly – I had to modify mine. I believe I added some cotton batting to make them fit better.
C) Glue them on using 3M spray glue (home cheapo) heavy duty. Use your hands (CLEAN!!) to add pressure and help adhesion.
D) Dry fit the backs over the frame – once you’ve confirms that all that should be covered – does, take off – glue both sides and attach. You should have a bit of excess on the bottom. This is what you roll up onto itself to attach to the bottom of the frame using staples. I don’t think glue would ever hold.
E) Now I went against ALL recommendations and advice on BCF and used staples vs. glue. The advantage: It’s what was on there and I had something I could reference. Staples can be pulled out and redone if you don’t like the fit / look / etc … I used the Senco “C” – a 3/16 staple (small) – anything larger has a almost certainty of pushing through your new material.
Staple gun:
https://cgi.ebay.com/LONG-NOSE-AIR-...5|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
E) For the bottoms – similar. Dry fit to satisfaction. Remove, spray with a small amount of glue and staple on the bottom. I re-do my bottom frames with wood (needed a good item to use with the staples). The metal bases simply were too expensive and I could not justify. My were beyond saving – they had used some sort of metal clip to secure the bottom seal material to the frame.
Good Luck – take it slow and you’ll have an incredible looking car. PM me if you have any Q’s or would like pic’s.
George
RickB
RickB
Thanks George,
I believe I'll have enough metal left to be able to use clips but I'll certainly be able to use most of your advice.
C Seat Cover Bugeye Sprite Mark 1 Spridgets 5
Upland Sprite seat back rake Spridgets 0
jollyroger Black seat kits for 62 sprite/midget Spridgets 6
W 1966 Sprite seat belts Spridgets 7
M New Seat Covers for MkII Sprite Spridgets 3
59sprite Seat Mod's - 59 Bugeye Sprite Austin Healey 8
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 7
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
