Sprite MK III upgrades - recommendations?
JimLaney
JimLaney
Kurt, I have a sway bar in my boxes/piles of parts. I think the oversize is 5/8" so this in the standard. I found an attachment plate for the A arm on eBay but just one. It appears that two would be required. I could fab one but will just order in case the steel is more than just mild variety.
JimLaney
JimLaney
Saxman: where did you get your LED panel lights?
A few minor thoughts:
- real air cleaners (your choice; keep the originals but replace them with something that will keep more than just the gravel out)
- clean up the SUs
I was also thinking that adding Sophia Loren to the passenger seat would be a worthwhile upgrade, for those of us of similar vintages to the cars........ Doug
Perhaps Bardot would be another choice while ordering passenger seat filler.....
Any particular air cleaner set up you can recommend?
nomad
I like a 11/16 or a 3/4 bar but considering the condition of my roads probably stick to the 11/16 in the future. Those both need re-enforcing.
Kurt.
twas_brillig
No real suggestions for air filters; at one time I cobbled together a couple of aluminum plates so I could stick the standard paper air filter between them. THese days we've got Webers, and are trying to fit Unipods onto the velocity stacks on one and a Warneford brand with some sort of foam filter. I kind of miss the old paper ones, 'cause them I could see if they needed replacing or not. Doug
PS: Jim - we have a 3000 with the wee seats in the back; I'm thinking Sophia in the front and Brigitte might fit in the rear....
JimLaney Sprite MK III combined master cylinder issue Spridgets 10
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
abarth69 WTB Sprite MK III Steering wheel Spridgets 10
R 1966 MK III Sprite Austin Healey 9
Tullamore Dash turn indicator. Sprite MK III Midget MK II Spridgets 1
im_a_hypnotist 66 sprite mk III dual master brake/clutch cylinder Austin Healey 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
