Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar
britishcarfreak
The early spitfire handling problems were of course partly solved by the swing spring etc of the later cars. I don't have access to that stuff and was wondering how to improve the handling of my fixed spring mk1. I've heard of camber compensators and underslung bars but don't really know any specifics.
I figured that there must be an easy way to mount a sway bar across the chassis and onto the radius arm rods to kind of link the left and right wheels together and thus reduce the likelyhood of one wheel tucking up.
Can anyone tell me why this wouldn't work? It surely can't be as easy as I think because surely the factory would have done that in the first place. I understand that a sway bar essentially brings independant suspension back to being like a live axle but who cares if it loses a bit of flexibility in return for more predictable handling on the edge?
piman
Hello Glen,
a rear anti roll bar will not do anything at all to prevent 'tuck under' It purely increases roll stiffness. The idea that it makes the suspension more like a live axle is not true.
Lowering the rear will help, but the thing to do is not to lift off in a corner as this causes the rear to rise and the wheels then go to positive camber and lose grip.
It should be relatively easy to add straps to limit the amount of droop in the suspension but I can't say what that would do to the ride?
Alec
B
britishcarfreak
Hmm I had thought that increasing roll stiffness and tying the two rear wheels together would in some way decrease the likelyhood of tuck in of the rear wheels as the likely hood of the rear becoming lifted on either side would be decreased.
Seeing as it must be relatively easy to fit a bar does anyone think I should try it or am I wasting my time?
Someone must have had a go at this in the past.
piman
Hello Glen,
yes it will increase roll stiffness and also that will increase oversteer. It resists the body rolling but does not actually tie the wheels together. The tuck under is a function of load on the rear spring, reduce the load and the camber angle goes towards positive and the outer loaded tyre loses grip. Worst case is to brake while cornering. The anti roll bar has no resistance to up and down movement of the body only relative movement of each wheel to the other.
Alec
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
B Spitfire Spitfire Mk1 Rear Spring Shape Triumph 7
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
J Spitfire Spitfire MK1 or 2 gas pedal bushings Triumph 11
JBann Spitfire Oil Filter for Mk1 Spitfire Triumph 7
JBann Spitfire Do you think it's worth it? - 1964 Spitfire MK1 Triumph 33
JBann Spitfire Triumph Spitfire mk1 - Height restrictions? Triumph 25
J Spitfire Spitfire MK1,2, or 3 trunk help Triumph 0
T Spitfire Help and Picture need for a mk1 spitfire Triumph 1
T Spitfire Spitfire top install mk1 or mk2 Triumph 2
T Spitfire Spitfire mk1 breather tube Triumph 14
T Spitfire Will not restart after warm up, Spitfire mk1 Triumph 15
G Spitfire mk1 mk2 spitfire clutch conversion ?'s Triumph 7
B Spitfire Spitfire Mk1 Steering Rack - can there be stops? Triumph 0
B Spitfire Tandem Brake Cylinder on a Spitfire Mk1 Triumph 4
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
