Spitfire Spitfire lights
Trevor Triumph
I installed a new wiring harness in my wife's MKII Spitfire after letting a lot of smoke out - burned / heated / melted the red circuit from the left rear lamp to the front of the car, under the dash. The folks I bought the harness from suggested adding a fuse in the red circuit. Since electricity is really a magical art, are there any suggestions in placing the inline fuse?
Since the harness is new, my neighbor, a car guy also, suggested relays for the headlights. I found a diagram, but I don't know exactly where to install the apparently two relays, high and low beam, where to cut the wires, and where to open the vinyl tape to get at the headlight wire.
Other problems: the overdrive is not operating at this time, and the gas gauge has issues - registering a full tank.
Trevor Triumph
DavidApp
Hello Trevor
On the TR3A there is an inline fuse that was added by Triumph that goes between the light switch and the tail lights. It is right under the dashboard.
Relays in the headlight circuit can help as they reduce the load on the light switch. There may be some wiring information on the web on adding relays to the headlights on a Spitfire.
What kind of overdrive does the Spitfire use. There may be an interlock so the overdrive only works on certain gears.
The fuel gauge may be a bad ground to the sender or a bad sender/gauge.
David
T
Trevor Triumph
Thanks. I'll add the in line fuse near the switch on the "lights" side. I'm thinking the relays for the headlights may take some effort - I may have to undo the tape wrapping. Perhaps it is a ground, since the gauge worked properly before the harness replacement. I wonder if I have the wire from the voltage stabilizer on the wrong terminal.
T.T.
Madflyer
When adding anything to elect. circuits have a print made that show's additions, using a fuse block say the new blade fuses ( some fuses glow when blown ) NOTE UK AMP values are not the same as US. If headlights are upgraded a relay is needed. Instead of opening harness find a opening the new fuse block with added space is or may be best access and looking.. As for the gas gauge it reads to ground so clean and the float may be bad not the sending unit. When replacing wiring clean all ground connections. Madflyer
T
Trevor Triumph
So perhaps I'll save myself some labor if I let the red circuit alone. Good news.
I'm thinking I have wires in and out of the voltage stabilizer and perhaps the at the gas tank somehow mixed up. The gauge was working before I changed the wiring. In the next day or two I will redo the instrument panel, I can't find the proper wire for the wiper motor (bad lighting) and there is a leak at the oil pressure gauge. There seems to be a "jumble" of wires behind the instruments and the copper tube for the gauge adds to the mess.
T.T.
T
Trevor Triumph
The story that never ends... The wiper and blower motors work after replacing the fuse. The fuse looked alright, and when attached a light it worked eventually. The fuel gauge appears to be working. Now to tackle the overdrive and oil leak. Thanks for all the suggestions.
T.T.
T
Trevor Triumph
I spent the day, Saturday, working on electrical gremlins: fussed with the another car's overdrive solenoid - maybe it is OK. I'll put it in and find out. The important thing is my wife's Spitfire: ALL lights work, overdrive, blower motor and wipers work. :encouragement:
The horn even worked for a while. On the way home I heard the sound of something breaking and sure enough the horn wouldn't respond to the steering wheel horn button. The sort of ball end to the horn brush broke. I replaced the slip ring using an incorrect part or the horn brush is the wrong one. I installed an aftermarket steering wheel; I don't remember the brand.
Any ideas?
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
F Spitfire Spitfire 1500 Dash Lights Triumph 1
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
