TR4/4A Shop with lift ideas
Rut
I'm starting to work on plans for a new shop and would like your input. I can probably get a 30x40 shop in the old pool house/shop space and I'll go with 12' ceilings and a 2 post lift. Please let me know your thoughts on 'must haves' and 'can't do withouts'...I do plan on piped in air and dedicated circuits along with full plumbing.
TIA, Rut
3798j
Bronze
Mine is a 42x28 I had built more than 10 years ago. I'd suggest thinking about going with a taller ceiling for the lift bay. I went 13' 6". While 12' would work for the British vehicles, it would be pretty tight for pickups and such.
Rut
Rut
Jay,
Thanks, I do have a pickup truck and need to consider both weight and height. I will probably be limited to an entrance on the harrow end due to log size and shape.
Rut
3798j
Bronze
Rut, I see you've asked about 4 post lifts (over on the Spridget forum). Thought I'd give you some thoughts on why I chose the 4 post....and to say thanks to malbaby and Kevin for their comments.
Wow..what a garage and contents.
Even my wife said, Wow!
Hey thanks guys. Glad you approve.
I went with a 4 post lift and two rolling jacks. I chose it over a 2 post because of the variety of cars that I would be lifting. I couldn't be more please with my lift and have no regrets.
The rolling jacks aren't cheap, but boy are they a pleasure to deal with.
You can lift one end of the vehicle or both...depending on the task.
As was commented over on the Spridget forum, suspension work can be problematic, but it's not impossible or difficult (here I'm re-bushing the leaf springs on my '55 F100.
Makes changing oil a pleasure (no more creepers).
And the feature of additional parking when needed.
mgedit
I was also going to suggest that a 4-post might be more versatile. Love mine. Although I don't have the sliding jacks. Cheers, Mike
Rut
Rut
Jay,
Thank you, that is exactly the information I need on lifts and I'm leaning toward exactly what you have. Having the lift on casters solves a lot of my issues with space and storage.
Thanks, Rut
Rut
Rut
Guy,
Thanks for that link. All of you are offering very good advice, so please keep those ideas coming!
Thanks, Rut
malbaby
Rut...what is the style of roof you intend to build...I guess that there is a height restriction on your neighbours boundary.
Rut
Rut
HOA restrictions can be a pain, but it is what it is. I've got to go with a hip roof to match the house which pretty much requires me to have 12' walls to get the clearance for the lift. I plan on installing an I beam along the ceiling for a track lift.
Rut
fpstude
Some thoughts:
-If an option, an interior height of more than 12 feet would be good. I have 12 feet due to code restrictions, but I need to be observant with larger vehicles. An example is our F150 pickup. It's radio antenna is not adjustable.
-I'm happy to have one sliding bridge jack. If I need four wheels up, I use the jack tray.
-I have aluminum ramps, a real plus over steel.
-The only time I have felt the 4 post lift was at a disadvantage was when working on under floor master brake cylinders, which I have on three vehicles.
GTP1960
Some thoughts:
perry,
off topic:
but do you have pics or online albums of your studebakers?
my Dad was a Stude guy. Had a champion & silver hawk, back in the day.
malbaby
Would your building regs allow you to have part of your hipped roof [perhaps on the non boundary side] immediately above your hoist raised....ie..A skillion section out from the ridge of the roof.
Rubicon
A couple of other things to consider for lifts would be a maxjax, they lift 6000 lbs and they are moveable. Bolt them into the floor when you need them, and removed and pushed out of the way when not in use.m they don't lift high enough to walk under, but a sitting creeper stool and you can roll around under your vechicle. Plus on the up side, you can put in lots of anchors to accommodate most size vechicles. I really like mine and would recommend it to anyone.
As for other shop idea are you gonna run in hot and cold water for a sink, heat? have you laid out your storage idea on paper?
My last peice of advice, is go as large as you can! You never have enough to space.
Geo Hahn
...along with full plumbing.
I'm sure at some point you'll get into looking at code and taxes. I've been told that where I live putting a toilet in a garage moves it from the realm of garage to living space with a commensurate affect on property taxes.
Tybalt
That's rather interesting considering that there was always a full bathroom in the plans for my shop building but it was explicitly forbidden to use the garage as living space under our county code so there was little impact on taxes. Now had it been attached to the house in someway, it might be another story but don't have anything definitive one way or the other on that front.
fpstude
To answer Guy in post #15:
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
becerrex MGB Car Shop in Salt Lake City MG 10
D Body/Paint Shop Recommendations Austin Healey 1
M TR6 What to do while at the shop... Triumph 5
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
D Shop lighting suggestions. Restoration & Tools 8
R Machine Shop St. Louis or Nashville Austin Healey 1
AngliaGT At a Local Repair Shop Spotted 1
drooartz The latest tool addition to the shop Restoration & Tools 25
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
C Looking for SoCal restoration shop Austin Healey 4
SCguy New British Car Repair Shop in Northern California, Sacramento, Auburn, I-80 Restoration & Tools 2
glemon Shop Heater Restoration & Tools 17
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
aero3113 Healey Shop on Long Island Austin Healey 9
O For Sale BMC Service Shop sign Other British Classifieds 3
D Houston Paint Shop Wanted! Restoration & Tools 8
Rut TR4/4A Shop progress Triumph 21
Rut Shop progress Spridgets 25
Rut MGB Shop progress MG 4
M General MG British car shop in San Antonio? MG 0
B Shop manuals Spridgets 10
Elva164 I've totally revamped my shop website! Racing 2
C Recommendations for paint shop in Southwest Florida? Austin Healey 0
R XK 150 Texas Repair Shop Jaguar 1
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
T TR2/3/3A Machine Shop Recommendations Needed Los Angeles/San Diego Area Triumph 0
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
Lotus Club SoCal GAS Shop Tour & Drive Lotus 5
D LED shop lights Restoration & Tools 10
B MGB Looking for a good paint/body shop MG 1
Rut First shop purchase Spridgets 3
Rut TR4/4A First shop purchase Triumph 6
Rut Equipping a shop Spridgets 14
Elva164 Some good exposure for our shop and for vintage racing! Racing 0
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
M Machine Shop in Pacific Northwest Spridgets 7
M TR6 Reliable repair shop !!!!! Triumph 8
MGTF1250Dave T-Series Big Day in the Shop Yesterday MG 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
T Best Shop Manual for BE Spridgets 9
simon1966 Ready to choose restoration shop Austin Healey 14
TomMull Shop LIighting Restoration & Tools 13
TomMull Shop Size Restoration & Tools 26
Gerard My new shop vehicle... Spridgets 13
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
