Here is a link that refers to street vechiles and smog equipment that race cars dont have.
Jerry
Motor Trend: 100 octane aviation "AV" gas is usually cheaper that 100 octane race gas. What is the difference between race gas and AV gas?
Rockett Brand: Aviation gasoline with an octane quality of 100 is often cheaper than 100 unleaded, thus it may look attractive to performance enthusiasts. First and foremost, 100 octane Aviation fuel contains tetraethyl lead (TEL); since 1996 it has been illegal to use leaded gasoline in a licensed street vehicle and you can be fined us to $25,000 for using it. Plus, leaded gasoline will damage the oxygen sensor(s) and catalytic converter(s) found in modern vehicles.
Aviation fuel is designed for low speed aircraft engines that run at 2700 to 2800 RPM at 10,000 feet altitude. Aviation fuel often contains hydrocarbons that are detrimental to the performance of a high-horsepower street car.
There are two grades of 100 octane aviation gasoline. One is identified as 100LL and is blue in color. The other is 100/130 and is green in color. The second number (130) shown for the green fuel is a measurement using a supercharged octane test engine. Although this 130 octane number is higher, it is achieved from an entirely different test and rating system than octane numbers determined with normally aspirated engines. For comparison, Rockett Brand 111 octane tests out at over 160 octane using the supercharged aviation method that indicates Rockett Brand 111 has a significant advantage in anti-knock ability over 100/130 aviation gasoline.
Read more:
https://www.motortrend.com/roadtests/tuners/112_0606_sf_high_octane_fuel/viewall.html#ixzz23XYQlWox
