Protection for the Pince Lucas of Darkness
LuckyLuke
What grease should be used when mounting the cable connectors of a Lucas wiring harness?
My idea was to use some grease to prevent moisture from getting into the connectors!
Keoke
Highly debatable. However, IMOP NONE--Fwiw--Keoke
P.S. Did you find any grease or moisture in em when you took them apart??
Dave Russell
Yoda - R.I.P
My 50 year old wiring harness was pretty beat up but had no bullet connector contact problems. When I installed the new wiring harness no grease in the connectors.
A lot of late model cars seem to fill every connection with dilectric grease. Not really sure if it helps keep out moisture or just retain any moisture that does get in. It certainly is messy & collects a lot of dirt.
R
RonMacPherson
Dielectric grease helps maintain contact and protect against water intrusion. Why wasn't it used 50 years ago?
It wasn't around then. You will find most of the upscale Marques are starting to include it at locations they consider consequential.
John Loftus
This is what prompted me to use it inside my new harness connections (and spark plug wire boots).
I would be very surprised that they would go through the expense and hassle of doing this if it did not have proven benefits in terms of corrosion resistance, reliability and reduced warranty service. As for the dust/dirt, I use the small applicator tip to apply the grease inside the connector and after everything is firmly pushed together clean up any excess (if any) that makes it to the outside.
Cheers,
John
Keoke
Yep they put that junk in there to save the cost of tining or plating the connector pins. By upscale do you mean "Ford"---Keoke
OH! by the way it was around 50 years ago but every one realised it be for Axles.--- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
OH! #2 A dielectric is an " insulator " and does not help maintain contact.
eschneider
With respect to everyone's personal opinion and experience, another alternative is "Kopr-shield".
Its a conductive contact grease sold by Eastwood. Since it's conductive, you don't want to use it anyplace where two connectors might short out (i.e., when rebuilding a switch)
I recently had a TR6 customer who was having all sorts of electrical demons with a brand new wiring harness. After tracing 3 problems to connectors, we pulled all the connectors and greased 'em. No complaints since.
We are located in a humid, dirty urban environment though - bad for electrical connections.
Where kopr-shield is't practical, I use silicone grease in moderation. Seems to keep surface corrosion at bay, and keeps bullet connectors from getting "stuck".
Just confusing the answer with another alternative. 8)
Glad to be of service!!!!!
Keoke
Well Eschneider, you just rang my bell again. When in this world did you ever see a grease that was conductive, ain't no such animal around. What is being done is the marketing people need some type of a gimmick to sell their product. So the take a dielectric; "Grease", fill it with copper granules and lacking any real imagination call it conductive grease.Grease is not conductive and the copper granules are the components that perform the conductive function the grease just keeps them put. OTOH ,Silicone grease used as you stated IMOP is a better choice.----Keoke
Keoke
Hi John, possibly so. The silicone grease that I am most familiar with is clear and a bit thick. Primarily used on the polly bushes during the install.---Keoke
GregW
I picked this stuff up at a local hardware store. I still had some of the ¼ oz tube left after installing the harness.
AndrewMawson
There is a product here in the UK called Electrolube, that removes oxide films on contacts:
https://www.electrolube.com/docs/contactlube.html
I first found it in use cleaning switch contacts in dirty process control environments, but now keep a spray can in the workshop for all sorts of odd contact / corrosion problems. Last usage was yesterday on the battery contacts of a radio transmitter used to track the path of underground drains by being pushed down them - hence the corrosion issues!
It's marvellous stuff, and although not originally put on bullet connectors, I have used it when re-assembling my wiring harness.
AWEM
Keoke
tahoe healey said:
Didn't point sets use to COME with a small bit of dilectric grease for the dizzy cam?
--Points! whats that TH ?? /bcforum/images/%%GRAEMLIN_URL%%/grin.gif I think some companies eons ago included plain ole grease for the cam with their points. However, I have Lucas NOS Dizzy point sets here an there ain't no grease in them.----Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/nonod.gif
And that stuff that Greg W used ain't nothin but tooth paste with some different writin on the outside.-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
John Loftus
Hi T.H.,
The point cam lube I have is different than the dielectric/silicone grease. It it formulated to keep the rubbing block from wearing (as fast) which changes the point gap.
Cheers,
John
Keoke
John Loftus said:
Hi T.H.,
Cheers,
John
Yeah I bet it been formulated alright, prolly just plain ole white vaseline fomulated in a new package.---Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Johnny
Yeah and Marth Stewart says to use vegetable oil on the light bulbs to make them easier to come out. She must have learned that little trick in prison.
GregW
Yeah, the plaque just sssslllliiiiddddeeeessss right off. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
eschneider
Ding-ding!!!
you make it so easy to torment you. <laugh>
here is the stuff. And it appears you are, indeed correct (not surprising) - reading the description closely, it says "promotes conductivity"..... rather than being conductive.
B TR4/4A License Plate Protection Triumph 12
R TR6 Radiator protection shield differences Triumph 0
RAC68 Battery Fuse Protection Austin Healey 101
D BT7 top/paint protection Austin Healey 5
NutmegCT New paint "protection"? Restoration & Tools 5
BN6_2197 Head Protection of Legroom Austin Healey 9
RAC68 Battery Powerline Protection Austin Healey 40
Rob Glasgow Paint Protection Film Austin Healey 14
T headlight protection film/stone guards Spridgets 2
60Bugeye Bare Metal Protection/Prep While Doing Bodywork Restoration & Tools 6
T This is why you wear protection Spridgets 11
T This is why you wear protection..... Triumph 14
Torsten Rust-protection: question about hollow areas MG 2
M Theft Protection Spridgets 31
pjsmetana Electronic Rust Protection... bogus? Triumph 2
RJS Engine Bay Protection During Winter Storage Triumph 8
G Wedge For those with no virus protection and a TR7 or 8 Triumph 3
mccalebr Electronic Rust Protection Spridgets 6
S Blue Tarp Protection Spridgets 16
LuckyLuke Rust protection and paint preparation Restoration & Tools 1
LuckyLuke Rust protection and paint preparation Austin Healey 5
Tinkerman TR2/3/3A Protection Strips, TR-3 Frame. Triumph 1
H heat protection Austin Healey 11
RobSelina Roll Cage Side Protection Spridgets 21
kbash Protection MG 114
nathandarby67 Metal protection during restoration? MG 15
H Paint Protection Film Restoration & Tools 10
C Hearing protection Triumph 7
T Wear eye protection!!!! Triumph 14
J Electronic Rust Protection Restoration & Tools 7
Hegg Lucas, the Pince of Darkness, and my Elan +2 Lotus 10
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
