Mystery leftover BJ7 Pieces
PeterB
Here are 2 parts I am just not sure where they go. I am thinking I saw the first one before going from the steering column to the area where the windshield frame bolts but I am not sure. If in fact that is it, how does it go? The second one I have no idea what or where. Any help would be great.
Thank you
roscoe
Sorry, too late.....buzzer?
roscoe
Great idea. I remember when I was a kid, probably around 1963, I was driving with my Grandmother ( nobody in the family was happy about her driving) and as we went down the road she suddenly asked me what that clicking noise was. 10 year old me said "that's your turn signal Grandma". Her response was "well of course I'll use it when I turn, it doesn't have to remind me". And on we drove.....
steveg
Very cute anecdote!
ozhealey
Gents,
The left picture (the bent/angled bracket) is actually correct and should be bent. It is for the steering column brace as indicated by Steve, and goes from the column to the windshield bolts but mine is original and is bent exactly as the picture indicates. The straight bracket described by Steve goes from the lower edge of the dash under the instruments to the forward bulkhead and passes next to the steering column. At least this is the configuration on my BJ7.
The other bracket looks aftermarket to me and I have not found it on my car despite a full restoration.
Cheers
Tony
steveg
Gents,
Cheers
Tony
Tony - perhaps you could post a picture of it as installed Maybe the design was changed between my BN6 and your BN7*.
Why would the factory bend a piece that was supposed to be a brace? It would have no strength.
Here's the dashboard brace parallel to the steering column - not the same piece - screw holes at either end, not 5/16" bolt holes:
*Addendum: I meant "BJ7" above, not "BN7".
ozhealey
Steve,
I dont have a BN7, I have a BJ7 the same as Peter, not sure if that makes a difference.
I have the straight brace in your picture above and as I indicated in my post in my car this is in place and goes from the dash to the firewall.
The bent bracket is absolutely factory in my BJ7 and looks exactly the same as Peter’s bracket. When I got my car a few decades ago it was an all original, untouched LHD BJ7 and the bracket was installed. The reason I knew what the bracket was immediately when I saw Peter’s pictures is because I recently converted the car to RHD and when I moved the steering across, the brackets all transposed as well. Amazingly, they all fitted perfectly on the RHD side as well and matched to the factory holes, including the factory bent bracket.
Noting the bracket is up towards the steering wheel end of the column brace, it could have been designed with a bend to give more knee room and/or to allow easier access to the instruments and wiring look behind the gauges. It is certainly a solid bracket which does not bend easily if at all from its current shape. Looking at the design and recalling my RHD conversion, the lateral movement of the steering column and brace at the dash is constrained by the very solid steering column end bracket which bolts to the dash/scuttle and the steering column bracket. This bent piece is more of a “steady” than a brace or bracket.
I confirmed the bend visually last night and will have a go tonight to get a picture and post it (noting the mirror opposite configuration of my now RHD BJ7).
Cheers
Tony
grimes6
Here is a image of an original untouched BJ7 with the bracket steering column steady AHB9176. This is a RHD vehicle and the bracket has a slight bend but not as much as the original image.
grimes6
Hi Steve,
Great pic but where is the steering column bracket ahb9683 which supports the steering column?
Regards,
Greg
ozhealey
Steve,
Not the best picture but you get the point.
Cheers
Tony
Duane_Rhynard
Maybe Duane Rhynard has official materials showing this brace.
Steve,
Coincidentally, I do!
According to all the original parts lists for the 6 cylinder models, the "Bracket - steering column steady" (Part Number 14B7458) is the same for all cars BN4-BJ8 and show a straight bracket. (Items 57 and 16 respectively, below.)
Both my BN6 and BT7 have a straight bracket. (I think, I'll need to check). Edit: I checked, and both my brackets have a bend!!
BN6 Parts List
BJ7-BJ8 Parts List
ozhealey
Gents,
I guess it could be unique to the BJ7 or perhaps just some of the BJ7’s. The parts for the BJ7/8 in Moss show a straight bracket and the same for the 100/6 and early 3000’s.
I spoke to two friends here in Australia with BJ7’s (both converted from LHD cars) last night and they both have the bent bracket.
Incidentally, if my bracket was straight it would be too long to fit across the space and the holes for the windscreen would no longer line up.
I guess the mystery remains.
Cheers
Tony
Duane_Rhynard
Gents,
Cheers
Tony
Tony,
I just checked both my cars and they also have the bend in the bracket. (Updated my post). My BN6 could have been modified, but my BT7 was completely original, so I would say the drawing detail (Straight) on the parts list is incorrect. This is the first "mistake" I've uncovered on the parts list other than omitted parts!
Thanks,
Duane
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
T TR2/3/3A Mystery Heel Panel Holes? Triumph 6
