TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps?
karls59tr
Bronze
I'm trying to track down the source of the annoying sounds coming from the rear end of the car. Here's what I have done so far. I have secured the spare tire so it does not move. I limited the amount of spare parts in the trunk and put foam underneath my toolkit.The rear springs have been replaced and all mountings seem secure. The rubber stops on the axles are in place. I can rock the back of the car up and down and it rebounds as it should with some slight squeaking only. That leads me to believe that the shocks are functioning and do not seem loose.
How is the body actually fastened to the frame at the rear of the car? Is it possible that the body is lifting off the frame when I hit a pothole or bump? I know that some have compared the ride of a TR3 to that of a buckboard but I still think something is not right. Any thoughts?
chlem
Agreed, re-check torque on mounting bolts for rear dampers. Mine loosen after a couple of thousand miles of driving. The rear dampers then clunk (move in the mount) over bumps, but not when pressing down/releasing body at a standstill. I use Stover nuts, too.
K
karls59tr
Bronze
Well it turns out that it was the mounting bolts for the rear dampers that caused the clunking as many of you had mentioned. The passenger side damper had one bolt missing completely and the one beside was just about ready to go. I replaced them with Grade 8 bolts, nuts and lock washers. Could not find the Stover nuts locally. Are they similar to Nyloc nuts? I might go with them if the present set up does not work out. Cant believe I lived with that irritating clunk for so long! Always something new to discover about these cars. Thanks to all who responded. 👍
charleyf
You should consider Loc-tite if you have to go back in.
Charley
Gundog61
Stumbed across this thread looking for a mystery banging in the rear end of our Healey as the OP described. Spent months looking for this, I am working on brakes so with it on jacks I went and check the shock. Sure enough the shock is loose and causing the banging. Thanks all
Geo Hahn
Repeating prior recommendations... Stover nuts are great for this fitting.
My use of socket head cap screws is just to enable getting everything tight in locations where wrench access is limited.
mt10flyer
The mounting holes on the my brackets became enlarged due to the wear caused by the bolt movement. So the bolts don't seat correctly and can move around. I used the grade 8 bolts and nuts with extreme torque idea, but eventually will have to replace the mounting brackets.
charleyf
I would suggest that you try filling the oversized holes by welding them closed and then drilling new holes.
Two cautions-- first you are welding directly below the fuel tank, so use some protective shield under the fuel tank also make sure the area under the tank is clean to start with.
Second --make a template of where those new holes need to be before you start.
Charley
K
karls59tr
Bronze
Charley
.....and plug the tank vent tube temporarily. (y)
KVH
I had this happen once--the bolt holes were ruined. On someone's advice here, I bored out the holes ultra-carefully, using a power drill held by hand, of course. I forget the size--either 3/8 or 7/16. I then tapped the holes for fine thread, IIRC. I then had to bore my new shocks as well. It really didn't take much time. Most of the time was spent with me worrying about how to drill straight into that threaded hole. Anyway, it worked great. Never had a clunk since. I used longer bolts that protruded beyond the backside of the mounting plate and put nyloc nuts there, too. Again, because someone here recommended that brilliant step. No welding. No down time. Good luck.
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
AN6-TX Application of Marvel Mystery Oil Spridgets 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
Y MGB A bellhousing mystery.... MG 3
P Mystery leftover BJ7 Pieces Austin Healey 18
warwick-steve Mystery Rattle Austin Healey 21
K Off Topic Mystery Windshield Brackets or ?? Triumph 6
warwick-steve Misfire mystery Austin Healey 28
ckeithjordan TR2/3/3A TR Mystery Thingy Triumph 13
S Marvel Mystery Oil Spridgets 7
D mystery Friday... Austin Healey 5
D mystery of the day... pedal block? Austin Healey 5
HighAltitudeTR3 TR2/3/3A Mystery Bracket Triumph 23
D TR4/4A water pump mystery hole Triumph 6
P TR6 Purple/Red wires & mystery bulbs Triumph 17
T TR2/3/3A Another Mystery Part Triumph 8
R TR2/3/3A Mystery part? Triumph 10
T 100-6 LHD/RHD mystery Austin Healey 7
T TR2/3/3A Mystery Heel Panel Holes? Triumph 6
